need help ... just picked up a 86suzuki 230s
Old Apr 10, 2011 | 09:44 PM
mmier007's Avatar
Default need help ... just picked up a 86suzuki 230s
well where do i start.... first of all it has a new carb kit in it and its tuned in but it runs for about a 1/4mi then dies but its not a fuel die it dosent bog down or backfire just quits even if i down shift and pop clutch it wont run it tries but no luck... sits for 30sec to a min and had a friend pull me cause i was tired of kickin the damn thing popped clutch fired right up but it does the same thing everytime runs for a bit and runs great no chuggin or poppin or boggin then dies....ok...... my though when i took a look at the stater there was oil in the bottom of that area i dont know anything about atv at all learning as i go seems like there should not be any oil in there at all or am i wrong plz help ive had the carb off 50 times cause i thought it was flooded or not getting enough gas this is the only thing i can think of
Old Apr 10, 2011 | 10:11 PM
2strokezilla's Avatar
Still sounds like a fuel problem. Try checking the fuel drain screw at bottom of carb right after it dies that would prove if you do or dont have a fuel problem. Then check if you have fuel flow out of your tank if all this checks out then start with spark issues.
Old Apr 10, 2011 | 10:46 PM
mmier007's Avatar
Default thanks for the info but...
ive done those things after it dies i can kick it and it starts right up but should i see any oil when i take off the stater cover when i popped it loose there was oil in the bottom of where the stater is and whats up with that decompression thing how should i use that is it just to ease kickin the damn thing also there is a hose coming off the carb and it goes under the tank but not hooked to it theres no where to hook it to the tank i unhooked it from the carb and blew thru it to see where it went and it looks like it ends in the frame under the tank
Old Apr 12, 2011 | 09:27 PM
Scooter86's Avatar
Knows Old ATV Questions!
Check the fuel tank breather for clogs. Another thing is after it dies(and you get stopped) open the gas cap and listen for a short rush of air. What happens is the tank vapor locks after a short time if the breather is clogged. It will run fine again once the pressure releases until it starts all over again.
Old Apr 14, 2011 | 10:10 AM
mmier007's Avatar
the tube coming off the tank is clear and the other tube going nowhere off the carb is clear also it just runs into the frame under the tank i havent checked the ones coming off the gearbox ill look at those later today
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
cboler9
Sep 24, 2015 08:35 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
