LT80 carb adjustment/ two screws wtf! help
Old May 22, 2011 | 04:39 PM
Eric W's Avatar
Default LT80 carb adjustment/ two screws wtf! help
okay guys just picked up a 1999 lt80, it starts right up everything works as it should really like this quad............except:
I am trying to adjust the air/fuel mixture aswell as the idle and on this stock oem lt80 carb there is a flat head adjustment screw on the foot brake side of the carb? BUT also there is a phillips head adjustment screw on the bottom bowl of the carb facing the left side of the quad (oppesite of foot brake side) whats this screw for?
I have not touched the phillips head screw on the bottom bowl of the carb but I have tried to adjust the flat head screw on the foot brake side of the carb and I noticed when I back the screw out enough the quad will idle down the father the screw is backed out an also that with this screw backed out pretty far if I give the quad more then just a little bit of gas it will bog down and die unless I lift off the gas quickly then it will idle.
Everyone tells me there is no air/fuel mixture screw on the lt80 but what the heck am I messing with then because its not just a simple idle screw or else it wouldn't bog
Old May 23, 2011 | 08:32 AM
LT80's Avatar
LT80 Expert
It IS the idle adjustment. LOL
The bottom screw is a drain for the carb bowl.
Maybe a plugged jet making the bog.
Maybe check the compression.
GregM
Mar 6, 2018 06:53 AM
ghost civic
Jul 20, 2015 12:36 PM
Wnthunting
Jul 9, 2015 03:02 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
