Oil Leak - 1987 LT230EH
Old Jul 29, 2011 | 12:18 PM
bnewph's Avatar
Default Oil Leak - 1987 LT230EH
The last few times I've gone out riding I've noticed my case leaking oil. I believe its coming from the shifter. Can the seal be replaced easily or will I have to crack the case to get to it? Also it only leaks when the bikes warmed up (leaks pretty good) could I possibly just need to go to a thicker oil? Currently I run 10-40 motorcycle oil in it.
Old Jul 29, 2011 | 01:46 PM
Trailrider230s's Avatar
yes the seal can be easily replaced. use a striaght screwdriver to pry the shifter seal out. it may be a pain but it will work. just be careful.
and when you put the new one on, put a little oil around the outside and inside edge, then find a deep well socket the same size as the seal and lightly tap it into the the hole.
exmotocrosser
Sep 13, 2019 06:12 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
wrencher82
Sep 24, 2015 03:39 PM
