What model is my Suzuki
Old Aug 12, 2011 | 04:28 PM
Twin_Stacks's Avatar
be sure your rear hubs are tight. they got loose on ours and the splines stripped out of the hubs. the axle was ok though. i believe the timberwolf has the same splines. i dont recall what year though, it was also a solid rear.
Old Aug 13, 2011 | 12:20 AM
lowproki's Avatar
What i notice that my carb looks oily....
And from the bottom of the engine i can see drops after a while... might have to open it up and gasket all..
Also at the start i see blue smoke for like 30 seconds and then i have to adjust the choke for it to stay on but no more smoke. But if i move the choke a little it will shut off.. The Quad feels great and runs great just need to find out how hard those things are to fix.
I now how to fix cars but never tried ATV's
Old Aug 13, 2011 | 12:23 AM
if you intend on keeping the bike, id get the shop manual for it.
Old Aug 13, 2011 | 12:29 AM
lowproki's Avatar
I have the original manual that says the basic but i want a servise manual or where it shows step by step building parts do you have a place
the manual i have says LT-F230
Old Aug 13, 2011 | 12:32 AM
  #15
lol, i meant the service manual. check ebay, thats normally the best place from what ive heard.
Old Aug 13, 2011 | 01:35 AM
  #16
lowproki's Avatar
I think im going to open up the motor once im done with the body.
Im going to do piston rings and hone it for the rings so if its oil thats going threw the rings. Also doing Valve Adjustments and port polish the intake side. Re-gasking the whole motor since it leaking oil. Should cost around 200-250 i hope.
Old Aug 13, 2011 | 05:22 PM
  #17
tomgodair's Avatar
Smoking on start up is bad valve seals, just buy new valves, $20, and a top end gasket kit $15 which should come with new seals and replace the valves and seals. Dont waist money on a top end piston kit if it only smokes on start up.
Old Aug 13, 2011 | 08:47 PM
  #18
lowproki's Avatar
Thanks a lot on the info I might just do that and while I'm at it rebuild carb
Old Aug 14, 2011 | 11:30 AM
  #19
lowproki's Avatar
I found the Valves but i can't find the Valve seals on ebay those anyone now what others seals fit
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
clscott84
Sep 21, 2015 10:16 AM
wendal
Sep 15, 2015 01:50 PM
Sep 1, 2015 11:59 PM
