Hard Start
Old Oct 10, 2011 | 03:09 PM
fmd's Avatar
fmd
Default Hard Start
Anyone have an idea to start my suzuki LT 230s easier? Very hard to kick, but once started runs and drives good. Thanks
Old Oct 10, 2011 | 07:26 PM
MITTERS17's Avatar
plug the air filter with and hand a be very carful!
Old Oct 10, 2011 | 10:32 PM
LT80's Avatar
LT80 Expert
Welcome to the forums.
Maybe a valve adjustment? Maybe they are out of spec.
Old Oct 11, 2011 | 11:54 AM
lt230inwiscasset's Avatar
Default fine tuning
have you adjusted the valve lash? it could be your low speed setting on your carb or maybe both. As for the difficult kickstart problem there isn't really much you can do about that. Maybe try a new spark plug as well. If you go to the lt 230 vault it tells you how to do all the fine tuning stuff you need to know.
Old Oct 11, 2011 | 03:35 PM
LT80's Avatar
LT80 Expert
"have you adjusted the valve lash?"
If the valves are out of spec, so is the compression release thus hard to kick.
That's what I was thinking.
Old Oct 11, 2011 | 03:40 PM
fmd's Avatar
fmd
Default Suzuki hard strart.
Thanks guys, I will start with the valves.
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
chinkapin
Jul 14, 2016 06:58 AM
Ty Speece
Jul 2, 2015 04:59 PM
1000gade
May 27, 2015 12:37 PM
