Flywheel Removal help on a 02 vinson 500
Hey,
I needing to remove the flywheel to replace the crank in this thing and the book shows two special rotor removers. A ( 09930-30721) and a (09930-31921) from what I've looked up one is (50mm x 1.5mm) and the other is (38mm x 1.5mm). Do I need both? If not which one do I need? The manual just ain't that good on this wheeler. Thank for any info.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
09930, 0993030721, 0993031921, 30721, 500, 50mm, attachment, flywheel, puller, removal, remover, rotor, specification, suzuki, vinson
