Quad 250 LTF
Old Jan 19, 2012 | 01:47 PM
Tdorsey's Avatar
Default Quad 250 LTF
I have serial number JSAAJ47A6T2102283 I i think it is a LTF 250. It runs fine but when you let off gas it will idel for about 45 sec. then cut iff. it will start right back up. The mechanic says they replaced the cockpit valve or something, pit **** maybe. but did not use the 170 dollar one. and used a 50 dollar one. the correct one had a vaccume to keep gas flowing, now i have the issue, Whay can be done any suggestions? also where can i find a manual on line?
Old Jan 19, 2012 | 08:31 PM
KiwiTel's Avatar
Hi,
maybe vacuum fuel tap / valve, will allow fuel through it when motor is running normally has a hose to the inlet manifold. Mechanic replaced with a standard on / off tap ?
Easy way to tell if a fuel blockage is to remove the fuel line running to the carb turn fuel tap on there should be a steady stream, if it trickles or stops ether a blocked filter of air lock in the tank
cheers
Terry
Old Jan 27, 2012 | 08:39 PM
Dreric's Avatar
I am not the expert, but i heard you need to make sure you plug the vacuum line to the carb for that to work well. Let me know what you come up with.
Old Jan 28, 2012 | 07:13 AM
Tdorsey's Avatar
they did somthing and there is a plug in wgat i think is a vaccume line.
Old Jan 28, 2012 | 07:15 AM
Tdorsey's Avatar
it has a hose pluged. i think it is a vaccume line, and it get gas fine just will idel for 45 vsec if no pressure is on the thorel. thanks.
Chillibean
1) Engine problems..
Sep 5, 2020 04:02 AM
Frisky2050
Apr 9, 2020 11:19 AM
greg74
Sep 10, 2019 03:03 PM
Ashley S
May 29, 2017 10:54 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
