Rebuilding LT80 head and piston
Old Feb 27, 2012 | 06:30 PM
dparkguy's Avatar
Default Rebuilding LT80 head and piston
I need to replace a badly scored piston/rings and have the head bored. The piston and head are original equipment on this LT80. Sounds like the LT80 can last for years with a fresh piston and ring job. What size piston and bore will work best? Cylinder head has very fine scratches from bad piston. Traced problem to the 2 cycle oil pump with the plastic gear drive. The gear went bad and the motor received no oil. Any help is appreciated!!
Old Feb 28, 2012 | 08:38 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
Pistons come in .5mm increments.
The first overbore is a .5 over. Then 1.0, 1.5, and 2.0
You only need to bore enough to eliminate any damage.
.5 usually does it.
You get the new piston then have a shop bore the cylinder to it.
It sounds like your head is OK. It could be shined up a lil if need be.
I only use Suzuki pistons or Pto-X pistons.
FYI: I've been getting Pro-X's at::
Lytle racing
877-431-8100
You should clean/service the clutchs too.
You can mix fuel/oil at 32:1 and forget about that bad oil pump.
I can get all this done for you if you don't have a local shop.
I also have some freshly bored cylinders here that I can exchange. They are bored to 1.5 over.
Old Feb 28, 2012 | 03:50 PM
dparkguy's Avatar
Thanks for the reply Jack. I've done all the work to the LT80 engine with it still installed in the frame. I did notice that there is a collecion of fluid in the lower end of the block which may include pieces of my piston. I'm guessing I should pull the motor to clean out the fluids and foreign garbage. Correct? If I pull the motor, is there anything I should be aware of that may make this a challeng or make it easier? I'm also needing a seat. Would even take a seat pan and make it myself to save some bucks. Any suggestions?
Old Feb 28, 2012 | 05:27 PM
dparkguy's Avatar
Forgot to ask how much you want for a cylinder exchange?
Old Feb 28, 2012 | 11:50 PM
LT80's Avatar
LT80 Expert
You can clean the motor out with the motor in if you stand it up on end.
I cannot guarantee 100% of the piston/crud comes out, but expierience tells me that if you do the best you can, it'll be fine.
Please email me me about the cyl.
Divergent12
Dec 30, 2017 08:33 PM
fordfaithful21
Dec 7, 2015 05:52 PM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
Bergmann
Aug 13, 2015 03:51 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
