help LT80
Old Jun 26, 2012 | 09:40 PM
skeets44's Avatar
Default help LT80
ok so i have 1990?? lt80 smoking like crazy? hoping not cracked heads...any thoughts
Old Jun 27, 2012 | 09:10 AM
95wolv's Avatar
A little more info would be helpful, did you just buy this and noticed the smoke, or have you owned it a while and it just started smoking? could be too rich of oil mix from the injector,or are you mixing your own gas, and what ratio? muffler could be full of unburnt oil, open the drain plug and see if a lot of oil runs out, you may need to pull the pipe and cook it in a bonfire to burn out all the oil and junk that could make it smoke. have you done a compression check? many things we need to know to give you a better answer.
Old Jun 27, 2012 | 10:22 AM
skeets44's Avatar
Default ok
it smoked a little now smoking a lot more i will get more info. im new to all of this so will get some help and more info thanks.
Bob E.
Oct 1, 2019 09:08 AM
QuadRiders
Oct 22, 2015 04:13 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
Bergmann
Aug 13, 2015 03:51 PM
