85 quadrunner 250 clutch problem
Old Aug 7, 2012 | 10:11 AM
vamped400's Avatar
Default 85 quadrunner 250 clutch problem
I picked up a VERY clean 85 quadrunner about a month ago now and i just got it running and going. When i put the wheeler in gear, it feels as if I was in neutral but if you rev it for a while the clutch will engage and when it does its all there and it usually wheelies. I have tried adjusting the clutch with no luck. any ideas on what would cause this? I think it has a centrifugal clutch if i remember right and a clutch that looked like a normal one. im no pro on these old wheelers
Old Aug 7, 2012 | 01:17 PM
vamped400's Avatar
now im just trying to narrow down if this is the "secondary" clutch or the centrifugal clutch. I have it torn apart now and the clutch basket has no notches either does the hub. the clutch plates look worn though. this is my first time working on a centrifugal clutch, so im not exactly sure what to look for for wear on that
Old Aug 14, 2012 | 10:30 PM
vamped400's Avatar
anyone? i also noticed that the outer centrifugal clutch thing had some pretty deep grooves in it. would this cause it to do what im talking about?
Old Aug 15, 2012 | 09:33 AM
BruceDeuce's Avatar
I had the same problem and I changed out the clutch plates with Red Line plates and its good now.
skinnyr6
Aug 25, 2023 02:18 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
cornermike
Jul 8, 2015 11:44 PM
bikedad3
Jul 2, 2015 02:15 AM
