Looking for help!!
Old Jan 15, 2013 | 06:21 PM
Tha-hood's Avatar
Default Looking for help!!
I have a Vinson 500 that was running fine, had a little bit of chatter when using rear brakes. Got stuck in the mud, and now it has chatter constantly. I need to know what I should look into or do....? Any advice is helpful.
Old Jan 16, 2013 | 03:17 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
so- maybe I'm not understanding correctly but... your atv is running fine, you had a little chatter from the rear brakes... you got stuck in the mud... and now you have a lot of chatter in the rear brakes?
If I'm understanding this correctly (and I may not be), it is in my professional opinion that you start your brake chatter diagnostic at the ...... drum-role please..................................... rear brakes.
either that, or the handlebar grip bearings might be worn out.
Old Jan 16, 2013 | 05:19 PM
Tha-hood's Avatar
The chatter is no longer coming from the rear brakes. It's coming from inside the clutch housing/case. I assume, anyways. I looked at it today and found that my front u-joint is broken, and I'm ordering parts. But, the chatter inside the clutch casing still worries me. Seems like it's gotten worse.
Old Jan 16, 2013 | 11:54 PM
LT80's Avatar
LT80 Expert
Better inspect further.
