Problem shifting thru High, Low, Neutral, Reverse. LT-A400/F
Old Mar 13, 2013 | 08:44 PM
Nick30605's Avatar
Default Problem shifting thru High, Low, Neutral, Reverse. LT-A400/F
I just bought a 2003 Suzuki Eiger 4x4 Automatic. It was owned by an elderly man that did not drive it for the past 2 years. When I try to shift it thru high, low, neutral, and reverse, it gets stuck and I have to force it in gear. Has anyone experienced this problem with a Suzuki?
Old Mar 14, 2013 | 09:34 PM
mla2ofus's Avatar
Maybe the idle speed is set too high.
Mike
Old Mar 16, 2013 | 08:08 AM
Normex's Avatar
Sounds very muuch like idle too high, but if the unit has not been run for the past 2 years, I would dump any gaz left in tank and refresh.
If it still shows symptoms afterwards I strongly suggest a new carb kit and with a dynojet kit set on 3rd notch and #126 main jet. You'll find a very different quad.
Just a suggestion
Norm
toonces
Oct 16, 2019 12:11 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
sara durrant
Jul 6, 2015 05:32 PM
bikedad3
Jul 2, 2015 02:15 AM
kukerdan
Apr 29, 2000 02:38 PM
