crank bearings
Old Mar 19, 2013 | 10:48 AM
trober_603's Avatar
Default crank bearings
does anyone know how hard it is to install new crank bearing and connecting rod bearings on a 92 suzuki lt230e quadrunner. i replaced rings not to long ago and its starting to smoke again i think the connecting rod bearings are bad making the piston flop around. ive never had the case even split so how hard is it to do?
Old Mar 19, 2013 | 01:42 PM
JustRandy's Avatar
Did you call vince?
Old Mar 19, 2013 | 01:54 PM
trober_603's Avatar
no sir i didnt! in my luck its always a chore..
Old Mar 19, 2013 | 01:58 PM
JustRandy's Avatar
You'll get the best advice from vince.
You'll have to decide if you can handle splitting cases and getting everything back together right. As far as engines go, this is one of the easier ones, but it still ain't easy.
You'll need to buy or borrow a flywheel puller too.
Old Mar 19, 2013 | 02:00 PM
trober_603's Avatar
ehhh lol sounds like id rather it smoke a little bit lol
trober_603's Avatar
i dont remember the crank moving alot tho when i had the piston off it felt tight didnt have any side play to the touch anyways
Old Mar 19, 2013 | 02:01 PM
JustRandy's Avatar
That's what vince would tell you to check if you would call
Old Mar 19, 2013 | 02:04 PM
trober_603's Avatar
ok ill have to give him a ring
Old Mar 19, 2013 | 02:09 PM
JustRandy's Avatar
Post back what he says
Old Mar 19, 2013 | 02:18 PM
trober_603's Avatar
ok will do
pgamboa
Dec 24, 2023 11:52 AM
2quiker
Mar 22, 2022 08:36 PM
black798
Sep 9, 2015 07:42 AM
DM2015
Sep 7, 2015 10:36 AM
Elkaholic
Sep 6, 2015 02:44 PM
