2009 Z250 adjustable needle?
Old Mar 17, 2013 | 06:52 PM
j_mauld's Avatar
Default 2009 Z250 adjustable needle?
I've got an '09 z250 that is currently running very lean. I went to adjust the needle and saw that there is no adjustment on it. Is there a replacement needle that is adjustable, and if so, do you know the part number?
Old Mar 17, 2013 | 06:59 PM
JustRandy's Avatar
If all you want to do is raise it, put washers under it. There are 100s of needles to pick from. My favorite is the 5L1. Its a pretty rich needle with a sharp point.
Old Mar 18, 2013 | 10:48 PM
j_mauld's Avatar
Good idea, I'll give that a try.
Do you mind taking a look at this diagram and telling me what items 54 and 57 are?
http://www.partzilla.com/images/diag...1/107/0010.png
Old Mar 18, 2013 | 11:08 PM
JustRandy's Avatar
57 is an air jet. I don't see 54 pointing to anything. It could be the DIAPHRAGM ASSY... whatever that is.
Alpha Sports - Suzuki ATV Parts Catalog
Old Mar 19, 2013 | 07:58 AM
LT80's Avatar
LT80 Expert
#57 is the pilot jet.
#54 is the assembly as stated above. It's called a assembly but it physically looks like a gasket. It acts like a pump.
Old Mar 19, 2013 | 01:39 PM
JustRandy's Avatar
28 is the pilot jet
Old Mar 19, 2013 | 02:07 PM
LT80's Avatar
LT80 Expert
I stand corrected. And thank you.
I looked up #55 and seen pilot jet and didn't pay no attention ti the "air" behind it.
My bad. LOL
Old Mar 19, 2013 | 02:19 PM
JustRandy's Avatar
I kinda doubt it has anything to do with the pilot at all. Airjets usually meter air for the needle jet and changing that airjet would affect upper rpms. Yeah, it may (or may not) supply air for the pilot circuit too, but it doesn't meter that air. Its really tough to tell from that diagram as the airjet would screw into the part of the carb that isn't shown.
Old Mar 19, 2013 | 02:25 PM
j_mauld's Avatar
I found a copy of the manual, and it refers to them as
pilot air jet
enrichment diaphragm
Old Mar 19, 2013 | 02:35 PM
JustRandy's Avatar
Look at http://www.mikuni.com/pdf/vmmanual.pdf
Pilot air jet is misleading
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
cboler9
Sep 24, 2015 08:35 PM
wrencher82
Sep 24, 2015 03:39 PM
