LT80 need help with brakes
Old Apr 29, 2013 | 09:55 AM
mbriggs's Avatar
Default LT80 need help with brakes
I just put a new drum and pads on my sons LT80. It takes alot of work to get the drum over the new pads. I can get it on eventually after turning the wheel and pushing the drum...however, once the drum is on it's so tight that basically the brakes are "on".
I have the control lever at it's lowest point "zero'd" out if you will.
Any help!
Should i just try to run it until the pads wear enough to free the wheel? is this normal.
There is just no tolerance there.
let me know,
thanks
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
QuadRiders
Oct 22, 2015 04:13 PM
Whitelx1
Oct 2, 2015 10:55 PM
merryman
Sep 19, 2015 03:15 AM
