Motor swap question from a lt250ef
I Have a lt250ef made if 5/84 that has a great engine and drivetrain, but the frame and everything else is pretty rough. I have two options and was wondering if one of them was realistic.
1. I found a pretty decent 85 ef for 300 bucks in a junkyard with a blown engine.
2. i found a 80s lt250r with no engine for $200 and was wondering if my motor from the ef is a direct swap, or if there would be alot of painful fab work involved.
Thanks a million because this thing is giving me headaches.
The 85 ef in the junkyard, if it's a 250, should be a direct bolt in with the engine you have. you're 84 is likely an early 85 model. only difference between 85-86 e, ef, ef was internal gearing and a couple other very minor things engine wise. efg model just had some more accessories on it. (talking all LT 250 versions of the 85-86 quadrunner) if you decide not to use the engine you have, please pm me!
The 250 R engine has a totally different mounting layout.
TLC
Jul 11, 2015 02:28 AM
