1987 LT-F230 Magneto Rotor Removal?
Old Jul 13, 2013 | 10:23 PM
W1ldyovvnz's Avatar
Default 1987 LT-F230 Magneto Rotor Removal?
I am tearing apart my LT-F230, the previous owner dropped a valve and wrecked the top end and left tonnes of metal shavings in the bottom end. I have an 85 that has a good top end but the clutch blew apart on the bottom end and im making one out of the two. my problem is that I cant remove the Rotor, I made a bracket to fit into two holes that are drilled through the metal part of the rotor so I could turn it and try and remove it but no luck, anyone know how to take it off? I assume you need to take it off to change the cam chain anyway since the clearances between the casting and it aren't much.
and if you need a tool to take it off anyone have pictures of the oem tool so I can try to re-design mine to work like the oem one?
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
johnny1982
Sep 13, 2015 07:41 PM
