lt80 throttle issue
Old Jul 23, 2013 | 04:26 PM
skeets44's Avatar
Default lt80 throttle issue
so it starts up idles fine when I give it gas it boggs out then stalls. was running fine changed plug then that happen put old plug back in same problem..
Old Jul 29, 2013 | 08:11 AM
LT80's Avatar
LT80 Expert
Sounds like a plugged jet.
try cleaning the carb.
Old Jul 29, 2013 | 04:32 PM
skeets44's Avatar
Default ty
thanks did that and works
I have 2 and always seems to be a problem starting them. do they have a tendancy to flood? or battery issues?
Old Jul 29, 2013 | 04:38 PM
LT80's Avatar
LT80 Expert
They flood.
1 gentelman says that the fiber in the stock petcock deteriorates and allows fuel to go down the vaccum tube and into the motor. I'm sure this can happen.
I recommend a inline filter and manual shut off valve or new on/off petcock.
Shut the valve off and let it idle a while and they seem to start fine.
skinnyr6
Aug 25, 2023 02:18 AM
GregM
Mar 6, 2018 06:53 AM
skeets44
Jul 17, 2015 01:04 PM
Unzzy66
Jul 11, 2015 10:01 PM
MNatv89
Jul 7, 2015 11:36 AM
