LT 80 cranks hard then once running runs fine
I have an LT 80 When it's cold and you try to start it it cranks and cranks Then once running it runs fine Not sure what to do any help would be greatly appreciated thank you
Sometimes that does it.
If it does help but don't fix it, It'd be in the choke circiut. Maybe have to remove the choke plunger and clean/inspect (I'll presume you didn't take it out).
You did remove both jets and clean all the lil holes? Right?
O-ring behind carb is there and in place?
what should I do next any help
