35 or 38mm air striker carb for 85 quadracer
I have an 85 that is getting quite a bit of work done to it. Shaved head, race port on the cylinder, lightened flywheel, FMF exhaust, UNI filter with airbox (or if suggested I could remove the box). The bike will mostly be for duning and some hill climbing in the sand. I might have it in some mountain trails too, but not very often. I live in salt lake city, so operating elevation will be between 4000-5000, and higher when I am on the mountain trails. But, I would like it to be running the best in the dunes. Will the 35mm be too small? Will the 38mm be too big? I would like the power band to be in the mid to upper rpms because I think that is what is best for duning. Thanks for any input.
Mike
Mike
I have a 34 and a 38 for my 250r. Both work fine altho I'm told the 34 is too small.
I'd get the 38.
FYI: they are running 32's on 90cc motors. Surely 38 isn't too big for your machine.
If you are buying new....I'm a Lectron carb guy. No fuss carbs. I got mine at TC Racing.
I'd get the 38.
I got mine years ago so I have no Idea on price.
Yes, they fit right in.
Call Tom and see what he says. He's the go to man for getting a Lectron set up.
814-723-3514
tcracingengines.com
Altho, Tom knows little about computers (ok, he hates them) so there might not be much content to the site.
They are a trouble free carb. A big hole with a needle in it. I've never cleaned my carbs because of a blocked jet type problem.
814-723-3514
tcracingengines.com
GregM
Mar 6, 2018 06:53 AM
