86 LT230s clutch issue
Old Oct 28, 2013 | 01:22 PM
smallmike52's Avatar
Default 86 LT230s clutch issue
I recently replaced the friction plates and springs on my 86 LT230s, put it all back together and it shifts fine, only problem being I am not holding the clutch when it shifts...
When the bike is on and I shift from N to 1 it stalls, so the clutch is not being engaged... but again with the bike off I can cycle through 1N2345 without holding the clutch. Any idea what I may have missed here? or if there's something else that could be wrong? Any help is greatly appreciated
Old Oct 29, 2013 | 10:29 AM
Also I soaked the friction pads in oil before I installed them, but had other things to do on the motor before I filled it with oil. They probably sat for a week or two. Could this issue be because the pads are sticking?
Old Oct 29, 2013 | 12:53 PM
tomgodair's Avatar
When you pull in the lever for the clutch, does it feel normal? Like it takes a certain amount of effort to pull or is it super easy to pull. You might not have put everything together correctly.
Old Oct 29, 2013 | 12:55 PM
tomgodair's Avatar
You are holding the clutch when you shift from n to 1st correct?
Old Oct 29, 2013 | 01:49 PM
The clutch lever felt normal, but the gears were able to shift without the clutch being engaged. Yesterday I was holding the clutch, shifted from N to 1 and it stalled. I think the issue was the plates sticking, because today I had a chance to let the motor get nice and warm and it was shifting with no issues.
ghost civic
Jan 15, 2020 07:43 AM
Captjay
Jul 23, 2015 12:33 PM
ghost civic
Jul 15, 2015 10:48 PM
Unzzy66
Jul 11, 2015 10:01 PM
200es
Jul 10, 2015 09:09 AM
