lt80 ebay rebuilds
Old Mar 20, 2014 | 04:45 PM
LT80's Avatar
LT80 Expert
Stock is 50mm.
Yes, start with the 92.5 main jet.
Give the motor a cpl hot and colds for a break-in, then run it.
When tightening the pipe, draw down on the nuts evenly. No particular torque. I've never broke any from tightening them.
Sorry you bought the fatty.
I'm making a stage 2 motor right now for a fella in England. You know a Mick? LOL
Yes, I'm from the USA. Don't tease me...I didn't vote for Obama...LMAO
Old Mar 20, 2014 | 05:41 PM
Gabby6969's Avatar
sorry to be a pain LT80 but am i using the right plug in my motor everywhere on the net says bp7hs and other say bpr7hs i know the r isnt much different as for resister i have both types, also would i need to change hotter or colder at all to break in or when i have the pipe and reeds fitted etc or should i stay with 7 range, weather over here isn't that great at times hottest in summer is around 25c and winter worst is just below freezing. i also have a new bpr7hix iridium that i run in it a week after buying it and changing rear tranny fluid (10w-40 valvoline motorcycle oil?) and cleaned filter etc am i wasting money on this plug or will it run cleaner with it in, i also run on bp ultimate or shell super high octane unleaded, ok for this? cheer dude
Old Mar 20, 2014 | 06:23 PM
LT80's Avatar
LT80 Expert
The 7 will work fine. Use the Iridium plug. I use BR8HIX once modified. Cleaner? I suppose so as iridiums fire easier.
10-40 works but gear oil 80/90 should be used.
Yes, use the highest octane you have. FYI: I disconnect the oil injector and run 32:1 pre mix with a good synthetic oil.
Beeline08
Nov 11, 2016 04:00 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
r1pilot83
Sep 27, 2015 07:38 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
