91 Lt230e Throttle spring?!?!?!
Old May 26, 2014 | 12:08 PM
Dbak322's Avatar
Question 91 Lt230e Throttle spring?!?!?!
Ok i got this beater 91 lt230e. i got it for dirt cheap ands its a fixer upper. It starts and runs. . Well kinda.. anyway i have started rippin it apart and fixin it slower but surely. I have noticed that the (thumb)Throttle is a little off. when i compress it it slides normally but it dosent retract.. i opened up the thrumb throttle case and noticed the throttle return spring ( i think that is what its called) is a little rusty and not as springy as a spring should =P should i get a new throttle cable, and a new spring. . . Also can anyone help me find one of the springs online i was looking high and low all over the internet and couldnt find Anything that even resembles the spring i have please any help would be greatly appreciated thanx all
Old May 26, 2014 | 02:16 PM
LT80's Avatar
LT80 Expert
Check the hole that the thumb piece goes into the body. Sometimes they are wore out and cause that problem.
Sometimes it's how the cable is routed or if it's been damaged.
IMO: The carb spring is what actually returns the throttle to idle.
Old May 26, 2014 | 09:45 PM
Dbak322's Avatar
hey thanx man ill look at it after work 2morrow
mtdewmn
Jan 19, 2017 12:13 PM
brinkkl2000
Oct 16, 2015 11:08 AM
Proud Father
Aug 19, 2015 10:08 PM
dougn85
Aug 5, 2015 07:20 AM
Mphillips
Jul 2, 2015 07:20 PM
