2015 KingQuad 500AXI Power steering??
As far as I know the 2015 model is the same as the 2010 onwards KQ except for the twin spark head. These were the best Suzuki utility Quads ever made. They do have faults, the fuel gauge sender is rubbish, and you can only buy a new one along with the fuel pump assembly, so "big bucks." The rear suspension bushes wear quite fast but are fairly easy to replace. The 450 frame was bad for cracks and the 500 frame is so similar I am a bit worried it may crack, but have only had one in for service with a small crack, up to now.
A quick look at their specs proves it. http://www.atvreviewnetwork.com/enth...2=438002&go=Go .
You can't get a twig down the gas cap hole so most owners rely on the trip meter, I think Suzuki used a standard motorcycle pump/fuel gauge sender assembly, fine on smooth roads but the sender takes some hammer on the rough stuff. The 500 and 750 engines are different but they do share the same frame.
