Just brought home a 2001 LT 80
Old Apr 25, 2017 | 05:14 PM
  #21
Durch's Avatar
Thanks for all the advice so far, I'm sure I'll have more questions in the future. I'm waiting to give it to her when she gets out of school. She is a straight "A" student and she reads one grade ahead of where she is, so I want this to be surprise for her. I probably won't start tearing it down to the frame until late fall early winter. I want her to have fun with it during summer break.
Old Apr 25, 2017 | 07:54 PM
  #22
LT80's Avatar
LT80 Expert
Now there is a good idea!
I bet you're excited..we couldn't tell.
Ask anything anytime.
Old Apr 26, 2017 | 09:11 AM
  #23
DirtDevil101's Avatar
She's gonna love it!
Old May 3, 2017 | 07:01 PM
  #24
Durch's Avatar
Flipped the rear wheels around..
Added 2.5" durablue wheels spacers up front... I had to put them on the lathe and remove some material to get them to fit flush on the hub and clear the bearing housing.....
Added some LT160 shocks up front...
Old May 3, 2017 | 09:06 PM
  #25
LT80's Avatar
LT80 Expert
What shocks are those?
Sure does make some positive camber.
Old May 3, 2017 | 09:22 PM
  #26
Durch's Avatar
they are lt160 shocks (used) how can I fix the camber issue since there is no adjustment?
Old May 4, 2017 | 09:00 AM
  #27
LT80's Avatar
LT80 Expert
This is why shocks are a problem on these.
Look into some Elka's.
Old May 4, 2017 | 11:14 AM
  #28
Here is an easy way to fix that camber issue (and it is an issue)...these are made with 1/8" plate...Had to make these for the "long travel" shocks from Midwest-Mini...
The real issue is the single a-arm design...camber will go more negative as the suspension is compressed...hence why I went with a double a-arm set-up on my build...
Attached Thumbnails Just brought home a 2001 LT 80-img_1971.jpg   Just brought home a 2001 LT 80-img_1972.jpg   Just brought home a 2001 LT 80-img_1975.jpg
Old May 4, 2017 | 06:15 PM
  #29
Durch's Avatar
I think the camber might have been from the photo angle.... does this look better???
What do you think? The toe is a little off but I'll take care of that this weekend when I have a little more time
i might try that with the shock mount if it still looks screwed up
Old May 5, 2017 | 08:51 AM
  #30
easy way to check is to put a decent size level against the tire ()|
zero to a tad of negative / \ camber is the objective (I say a tad of negative camber because as you compress the suspension the camber goes a lot negative quickly)
