LT80 - Problems starting, and then stalling.
Old Apr 26, 2017 | 01:01 PM
  #21
DirtDevil101's Avatar
LT80's suggestion above will tell you if it's fuel starvation as it wont rev with the wheels off the ground...I'd try that 1st...
My neighbor's LT80 was running kinda same as yours...lifted the rear and worked the throttle until it cleared itself...took about 5 minutes but it might do the trick for you...
Old Apr 26, 2017 | 01:13 PM
  #22
Anders Berggren's Avatar
And by "clearing" it self you mean the carb?
Old Apr 26, 2017 | 02:02 PM
  #23
LT80's Avatar
LT80 Expert
No, The term "cleaning out" means when there is excessive fuel in the bottom end, the machine will bog/spit/sputter till enough enough air is let in (full throttle) and it clears (high rpm's)the excess out and it can run normally.
I think you need to clean the carb. I didn't see that you did that.
Old Apr 26, 2017 | 02:07 PM
  #24
Before the fuckup with the vaccumhose I stripped the carb in pieces and boiled it.
But I guess I'll have to remove the throttlestop and let it rip on high rpms for a while
Old Apr 26, 2017 | 05:37 PM
  #25
LT80's Avatar
LT80 Expert
LOL! I thought it sounded like hew didn't have his thumb in it.
Old May 1, 2017 | 10:34 PM
  #26
motc777's Avatar
Originally Posted by LT80
I think a new petcock should fix the stall issue. It seems like once put in the run position the vac isn't keeping the fuel flowing thus it stalls. I still install a cheapo on/off valve close to the carburator (auto parts store lawn mower section). This allows for the fuel to be shut off and the machine run till the carb is empty. This helps the common flooding issues of todays ethanol fuel.
Sure, might as well heat the pipe up and blow it out. Won't hurt.
Carb: Once off, remove the float bowl. You'll then see a black rubber thing that connects the jet area to the bowl. Throw that away. Then remove both jets and clean/soak/blow it all out. Make sure the jets are not clogged. Install. It helps to hold the o-ring in place with a lil grease.
Let us know how you make out.
Update:
Cleaned out the carb tonight. Man there was tons of dirt and parts of the disintegrated air filter in there. I cleaned all the jets, put in a new air filter, and put everything back together. Took a few start attempts but got started. Adjusted the idle screw and thought it was good.
I was able to run it flat out with the rear end jacked up and wheels spun fine. I then tried to ride it and it was o.k., but I still noticed the throttle was sluggish. It did not die at idle except once, but again, it would just not have that get up and go.
So, I'm getting that gravity fed petcock like you suggested. I intended to get it anyway like you said just because it's very hard to turn. Fuel lines are clear BTW. This was my first carb clean on anything. Now I've moved onto cleaning the carbs on my gas weed eaters that are sputtering.
Old May 2, 2017 | 08:14 AM
  #27
LT80's Avatar
LT80 Expert
now it's time to check the compression.
Old May 2, 2017 | 10:40 AM
  #28
motc777's Avatar
Is there a special type of tool for ATV's as opposed to cars?
Old May 2, 2017 | 10:55 AM
  #29
Or the clutches...
Most compression tools come with multiple adapters to handle the different size plug holes/threads...
Old May 2, 2017 | 10:59 AM
  #30
motc777's Avatar
Originally Posted by DirtDevil101
Or the clutches...
Harbor Freight good enough then to get that?
