84 Suzuki LT1?? needs front rim
So a friend of mine needs a front rim for the above LT but she has no idea the actual bike size, only it says LT1 but the year is correct. She sent me a picture of the rim and it is a six bolt pattern and she says it measures 100 mm center to center at opposite bolts.
I have looked but I don't see any aftermarket wheels for this thing. Tire size is 20x7x8 on the front.
Anyone know what to get and where to get it? Also if rim not available, then is there an adapter plates for this to convert it to some 4 bolt pattern?
Thanks.
EDIT: After looking at pictures on line this may not be a 6 bolt as 3 of those bolts look to hold the 2 piece rim together and the other 3 actually bolt to the hub??
Thanks.
From looking around the web, it would appear that the LT185 4 stud hub will bolt on and you swap the 3 stud hub. Anyone done this or confirm it works?
I also found a couple of used wheels on e-bay but you are looking at $90 each and some look rough.
