96 lt 80
Old Nov 21, 2017 | 10:27 PM
matt1716's Avatar
lt80 and dirtdevel- I was reading some prior posts. I think the guy I got this from put a Chinese carb on it because I don't see where the vacuum hose from the petcock can connect to the carb. The only ports are fuel line and oil which I did away with.
Old Nov 22, 2017 | 07:57 AM
LT80's Avatar
LT80 Expert
The rear port (closest to the motor) on the carb is where the petcock vacuum hose goes.
Old Dec 1, 2017 | 03:07 PM
matt1716's Avatar
So I replaced the pet **** with a standard on/off and capped off the vacuum port on the carb. Started right up and I let it warm up for about 10min.(note 45 degrees here). will idle all day but still seemed to flood out at first. The more I ran it the better it was. After about 30min I could go about 100ft before it seemed to flood out. I would back off the throttle and let it catch up then hit the throttle and it would take right off again. This is about 3/4 throttle. What's my next step or should I just keep doing this to clean it out per se. By the way even with the flooding it is running 100x better. Thanks for the help
Old Dec 1, 2017 | 03:13 PM
LT80's Avatar
LT80 Expert
Remove the plug in the pipe. That'll help clean it out.
Sometimes the pipes need to be heated up and blown out.
Old Dec 1, 2017 | 03:14 PM
  #15
LT80's Avatar
LT80 Expert
Ok, what about the carb? stock or a replacement?
Old Dec 1, 2017 | 04:19 PM
  #16
matt1716's Avatar
I'm not sure. I took it apart and everything looked new so I'm not sure if the guy rebuilt or ordered a new one. Gasket, float and needle all looked brand new.
Old Dec 1, 2017 | 04:21 PM
  #17
matt1716's Avatar
The way everything else looked that he supposedly rebuilt I wouldn't be surprised if it was a Chinese carb
Old Dec 1, 2017 | 04:44 PM
  #18
matt1716's Avatar
There is one gasket I didn't replace. The one between the lower end and jug. I forgot to order when I ordered the others. I didn't look bad though. But who knows. Would an air leek cause my problem
Old Dec 1, 2017 | 04:51 PM
  #19
matt1716's Avatar
Sorry for the million posts but I'm thinking as I'm going here. I did pull the plug and it had a bunch of dried crud. If you remember from my previous post I was having some oil like substance leaking from the exhaust but that stopped I figured that was just a build up of moisture. I will pull the exhaust plug in the morning and try that.
Old Dec 2, 2017 | 09:42 AM
  #20
LT80's Avatar
LT80 Expert
I think the float stuck and filled the motor with fuel.
BTW, I've had no problems with the cheapo carbs.
