LT80 front shocks
Old Dec 22, 2017 | 12:11 PM
dmolisher's Avatar
Smile LT80 front shocks
Hi,
Looking to upgrade the front shocks on my son's LT80. I read somewhere that the fronts from an LT160 are a direct swap requiring no mods. Like, they will bolt right on without swapping A-Arms and all the other stuff. Does anyone know if this is true? Anyone done it? Results? Any insight appreciated
Old Dec 22, 2017 | 01:06 PM
DirtDevil101's Avatar
Ah...yes, but the 160 shocks are designed for a larger machine & rider...so while they are marginally more adjustable, they are not a mini-quad shock...
Some will disagree with what I'm going to suggest, but I've tried a number of things and for the LT80 getting the Midwest Mini front shocks and making some easy upper mounts will give you an inexpensive setup that actually works really well...but that's my $0.02
Old Dec 22, 2017 | 01:10 PM
dmolisher's Avatar
Would the shocks from the 160 be good in the front for a 180lb rider? My son likes to ride the mini quads but constantly bottoms out...
Old Dec 22, 2017 | 01:28 PM
dmolisher's Avatar
Hi again,
are the midwest mini shocks direct bolt ons? You mentioned making upper mounts. I have no clue had to fabricate anything. My skills are basically tightening nuts and bolts. Ughh!
Old Dec 22, 2017 | 02:53 PM
LT80's Avatar
LT80 Expert
Maybe if you was to ask someone to make another set......
Old Dec 22, 2017 | 03:36 PM
dmolisher's Avatar
So I do need special mounts? Where can I get them? That is unless the LT 160 shocks are better? I’m looking for any thoughts? Like I was saying, the rider is about 180lbs. Thanks
Old Dec 22, 2017 | 08:37 PM
LT80's Avatar
LT80 Expert
You would need the mounts for the Midwest shocks (so we think). Try em without the mounts. He might love em.
Old Dec 23, 2017 | 05:15 AM
dmolisher's Avatar
Default Called Midwest
I emailed Midwest and they said the shocks are direct bolt on with no mounts needed. They do recommend their wheel spacers though for best results
dmolisher
May 6, 2020 11:32 AM
aqharoper
Sep 30, 2006 11:29 AM
Blaster2fast
Dec 7, 2003 04:20 AM
Honda400exneverdie
Aug 8, 2003 01:49 AM
