Eiger running rough
Yeah there an weird machine..I have had 5 in my shop at one time with this problem 3 of them was just flywheel and 2 stator and flywheel..When I have 1 of these in my shop now doing something weird I go straight to the flyheel some far I havent missed one [lol]I think the years are 2002 to 2007 also the Arctic Cat 400 is the same suzuki engine with same issues just order the suzuki flywheel though there the same but stator is different.
I have an Eiger here, not sure on year. I believe 03 or 04. I have an issue with an intermittent rough/ low idle, and a midrange stumble. It had a really funny low idle at first and the idle adjustment **** had zero affect on the idle. I could go all the way up or down with no change. I pulled the carb and cleaned it out 3 times now, adjusted the choke, replaced spark plug, cleaned and oiled air filter, fuel screw is at about 1.5 turns out, checked compression, checked valve clearances, did a leak down test, and checked generator output and battery condition. Everything checks out. Seems to do this with the fuel valve in run or pri position. It also will have a stumble at about a quarter throttle, runs out fine. If I run the quad in that 1/4 throttle and come to a stop it will stall out. I pulled the needle hoping to find it was adjustable, but it isn't. I don't know ehat else to check. Funny thing is I did all the checks, put it back together and it seems to idle fine, but still has that stumble. Old spark plug was pretty black, and if I hit the choke on the quad dies right away.
If your talking about the fuel/air mixture on the front bottom of carb? the recommened setting is 11 1/2 turns out. I dont care what the people on here are going to say. They are going to call me crazy. I had the same problem and thought no way is that the setting. I set mine at 11 turns out and havent had a problem since
can anyone here help with where the air/fuel mix screw is on the carb of a 2005 Eiger? Took the thing apart and got it started finally. I can give it gas without it dying but when I pull the choke lever up it dies. I can run it with the lever down, which is open I believe. I imagine it isnt good to run it like this. I cant find the screw to adjust make the adjustments. Someone on here have an idea?
