Suzuki lt50 (genuine or copy)
Old Mar 15, 2018 | 03:33 AM
Yes the Linmax uses premix, no separate oil tank. Suzukis and Linmaxes are pull start only. Necht made the same bike with an electric start, the Necht 2003. Strangely, the Necht 2004 had the same Suzuki copy frame and plastics but fitted it with a Honda C50 Cub clone four stroke engine.
Old Mar 26, 2018 | 06:12 AM
Cpr42845's Avatar
Originally Posted by merryman
I would guess at genuine, as the oil injector pipe is connected, and S is cast in the RH side engine cover. Linmaxes don't have this.
Merryman - I can only see one pipe coming from the 2 stroke tank (black rubber pipe). What the clear pipes coming out of the carb? Should there be a direct oil feed to the carb from the 2 stroke tank?
Old Mar 26, 2018 | 06:58 AM
Cpr42845's Avatar
Old Mar 27, 2018 | 02:48 AM
No the black oil tank pipe goes to the oil pump on the crankcase, and a thin orange plastic pipe goes from the pump onto the carb. The fuel pipe goes from tank tap to carb, another, clear plastic pipe is the drain/breather this points downwards from carb bottom.
Old Aug 10, 2024 | 08:25 PM
  #15
Gamz85's Avatar
Default Merryman
yes the linmax uses premix, no separate oil tank. Suzukis and linmaxes are pull start only. Necht made the same bike with an electric start, the necht 2003. Strangely, the necht 2004 had the same suzuki copy frame and plastics but fitted it with a honda c50 cub clone four stroke engine.
merryman coukd you please message me it wont le me message you and i need help with my lt50
Old Aug 11, 2024 | 02:45 AM
  #16
Just ask the question in the Suzuki section on here, preferably starting a new thread. That way, if others have the same problem, the answer is (hopefully) here for everyone to see.
SherpaT350
Jan 18, 2007 08:57 PM
stormy
Dec 5, 2002 11:30 PM
GuyRaptor
Feb 11, 2002 03:01 PM
jeepin
Jan 25, 2001 09:29 AM
