96 Suzuki King Quad 300 shakes and wobbles
Old Mar 28, 2018 | 09:41 PM
Jram's Avatar
Default 96 Suzuki King Quad 300 shakes and wobbles
Hi. I have a 96 Suzuki King Quad that wobbles and shakes. It shakes when I'm accelerating or engine braking. It also shakes at low speeds, but it doesn't shake when I move it in neutral, so it's not a tire problem. It probably has to be a transmission or U Joint problem maybe? When I accelerate slowly I can feel the 4 wheeler wobble from side to side. I haven't noticed any slipping or anything like that. Also, if it helps, it does it in 2 wheel drive and 4 wheeler drive. I have tried it on high and low and it does it on both settings. What do you guys think could be the problem? I appreciate any possible solutions.
Old Mar 29, 2018 | 02:44 AM
The fact that it doesn't do it in neutral, when coasting, means it is probably the rear end driveshafts so check them for faulty UJs. Check all wheel bearings, splines, front prop shaft UJs, driveshafts and CV joints too.
Old Mar 29, 2018 | 10:24 AM
Jram's Avatar
Thanks for the response. I will try and check out all of the stuff you mentioned. I hope it is something simple.
cscotter
Aug 3, 2008 11:01 AM
cscotter
May 2, 2008 01:12 PM
blk_tmthy
Jan 4, 2008 12:32 AM
yamahablaster23901
Jun 28, 2006 01:10 AM
lt250RaCeR88
Jan 24, 2006 11:25 PM
