2002 lt80 carb prob
Old May 10, 2018 | 08:38 PM
proverbs227's Avatar
Default 2002 lt80 carb prob
so now to my next issue. on my carb the little brass tit that connects to the hose behind the choke **** broke off.is this a replacabe part, if so what is it called. If not replaceable what is a good cheep carb to buy, thanks
Old May 11, 2018 | 06:28 AM
Old May 11, 2018 | 07:56 AM
DirtDevil101's Avatar
That's the oil injector line...don't think there is a "part" for it, but you should be able to drill it out and replace (it's just brass)...or just block it off and run pre-mix. There are a ton of Chinese replacements for less than $20 on eBay or look for a decent used OEM...
Old May 11, 2018 | 09:08 AM
what all is required to just mix fuel on my own. I read about a plastic piece on crank. or do i just drain off oil reservoir and then plug the line
Old May 11, 2018 | 10:03 AM
Real easy:
1) plug open hole in carb
2) remove oil tank & line (just dead weight now)
3) remove clutch cover, remove small black plastic key (just slides off) on crank, replace clutch cover
4) pre-mix with good 2-stroke oil (Jack {LT80} suggests 36:1
Optional: remove oil pump and fab up a block-off plate
Old May 11, 2018 | 10:17 PM
LT80's Avatar
LT80 Expert
A good synthetic at 32:1.
You can just drain the tank and remove the plastic piece when you do your regular clutch maint...
Old May 12, 2018 | 08:52 PM
I got a bottle of amsoil 2 stroke predator. It suggest 50:1. should i still go 32:1
Old May 13, 2018 | 08:50 AM
LT80's Avatar
LT80 Expert
I usually do what is stated on the bottle.
Old May 14, 2018 | 09:17 AM
one more question for now lol. what is the oring size for carb that goes in black spacer. I got an oring shelf here at work, just dont have oring with me. Im asking before I forget lol
Old May 14, 2018 | 09:33 AM
LT80's Avatar
LT80 Expert
A generic o-ring may work, don't know. I use the Suzuki O-rings. Might as well take a few home.
cycodad
Mar 21, 2005 09:36 AM
FRAME
Nov 7, 2004 06:00 PM
raptoric
Apr 30, 2004 08:24 PM
450Rutmaker
Aug 18, 2003 09:27 PM
racer20
Mar 14, 2002 11:13 AM
