2016 king quad 750 starting/electrical problem
Old Nov 4, 2018 | 09:57 AM
joeldub1121's Avatar
Default 2016 king quad 750 starting/electrical problem
I’m having a problem with my 2016 kingquad 750 when it comes to starting it. When I turn the key and then press the start button it makes a weird noise and will not start, but if I let the quad sit with the key in the on position for 5-10mins and then press the start button the atv will fire up. Anyone have any idea why it’s making that noise at first and won’t start right away? Thank you.
Old Nov 5, 2018 | 03:18 AM
Fuel injected bikes make a low buzzing noise for a few seconds after you switch on as the electric pump pressurises the system. However if it makes a loud buzzing noise when you press the start button, and won't spin over, you have a loose connection, a battery terminal, or solenoid terminal, or earth lead, is loose.
Old Nov 5, 2018 | 01:54 PM
thank you I will look and see if I have any loose connections, because the noise is definitely a loud buzz and the bike will not turn over.
puggerton03
Jul 3, 2017 04:50 AM
KingQuad750AXI_BlackBeauty
Aug 24, 2016 12:59 PM
Michael Worley
Jul 12, 2016 11:14 AM
IB Cristina
Newsletter Archive
Jan 26, 2016 07:00 PM
Nov 27, 2015 12:25 PM
