Ltz 400 will not run!
Old Mar 9, 2019 | 09:36 PM
Drewberger88's Avatar
Default Ltz 400 will not run!
I replaced the one way bearing today and went for a ride. The quad died and the starter would not turn over the engine. Anyways I took everything apart and the flywheel nut came off and the flywheel came unpressed I put it back together and now it is trying to start fine. But it wont fire unless I pop start it even then it will only run until my brother stops pulling me and it wont rev up when he does it's like a dead idle and then it dies! I am thinking the fly wheel damaged the stator, but what do you all think? Is there an easy way to check the stator without an ohm reader because I dont have one.
Old Mar 10, 2019 | 04:25 AM
More likely knocked the pulser coil for the timing on the outside of the flywheel. The gap between coil and flywheel pip is fairly critical, it won't be adjustable, but if the bracket is bent, you may be able to bend it back.
glit
Dec 10, 2010 09:34 PM
Dolter1
Aug 17, 2010 07:12 PM
RaptorOwner
Jul 1, 2006 03:23 PM
