Suzuki Vinson 500 4x4 carburetor problem
Old Mar 10, 2019 | 10:47 PM
Postman125's Avatar
Default Suzuki Vinson 500 4x4 carburetor problem
The exhaust pipe turning red out of head. Popping back when lettering off throttle. I have cleaned carburetor twice. The air adjust makes no defiance all the way in or all the way out. I cheek the valves and are int 4 thousand ex 6 thousand. Don't know what I'm missing? I bought the quad last week it has had this problem a while because it's melted some plastic around the exhaust pipe. Any help is appreciated. Thanks
Old Mar 11, 2019 | 04:08 AM
With the bike being new to you, the previous owner may have done anything to it. Is the air filter or exhaust modified? Jets may not be standard, I would check the valve timing too, it could be a tooth out. If you are sure the carb is OK, I once had a Kawasaki 300 with a cherry red exhaust, and it proved to be a soft exhaust cam, simply wasn't opening the valve long enough to let all the gas out, valve clearance was OK as it wasn't the follower, but the cam lobe that had worn.
MikeCim
May 22, 2006 10:23 PM
MikeCim
May 20, 2006 04:51 AM
FastestBlaster
Feb 11, 2005 04:12 PM
MJE
Jun 29, 2004 07:45 PM
