Drive Belt Recommendations for 2005 Vinson 500 Automatic
I used to have a Kawasaki and the drive belts were 125 and aftermarket belts were 75. Oem belt would go for 3000 miles where aftermarket belts would only go 1000 miles and performance was poorer. Your money and your machine.....Suzuki has always been extremely high on repair and replacement parts, the number one thing that kills there sales. Otherwise they make good machines!
I have used Dayco belts and they seem to be OK. All you can do is try one and if it doesn't last, use a different make next time. Give the belt box and pulleys a good clean when you take the old belt out, and make sure the pressed steel thing the rollers slide against is onto the splines, before tightening the centre nut or bolt up.
