Suzuki Lt80 not running good
Old Sep 27, 2019 | 06:56 PM
Massey1's Avatar
Default Suzuki Lt80 not running good
Working on neighbor LT80. cleaned carb , air filter bad ordered so is not on yet. Start and it smokes no power, removed exhaust and I ran for couple seconds runs good. I cleaned exhaust ,reinstalled ran good for a minute and idles down and no power. compression after running 100 psi . turn gas off and as it runs out of gas and it starts to run good till out of gas . got good spark while it runs bad or good. is there a good replacement carb? or are kits any good? other ideas like low compression,Thanks
Old Oct 3, 2019 | 07:55 AM
LT80's Avatar
LT80 Expert
OEM carbs are best but they can go bad if in dusty conditions. If it's flooding (which I suspect) you may want to get a kit (OPT liked Shindy kits) and swap out the float needle and seat.
The comp (at 100) is ok.
What did you do to the exhaust to clean it?
vester1426
Jul 22, 2011 08:54 AM
kjensen75
May 27, 2008 03:52 PM
TLAWYER
Jan 1, 2008 02:16 PM
gerrit
Sep 7, 2004 08:53 PM
