Top end time? With video
Old Apr 19, 2020 | 04:08 PM
SharpTJ1's Avatar
Default Top end time? With video
So the kid was riding yesterday when it all of the sudden lost power. I was able to milk it into the garage. Now...
On jack stands, you have to feather the gas, until you get mid - range then it's runs off fine.
On the ground, it just bogs and won't go at all.
You can hear the big toward the end of the video.
Old Apr 22, 2020 | 08:26 AM
LT80's Avatar
LT80 Expert
Service the clutch's.
Do a compression test.
Old Apr 22, 2020 | 08:52 AM
SharpTJ1's Avatar
Compression tested at 120 psi cold this morning. I do clutch today and see
Old Apr 22, 2020 | 09:25 AM
SharpTJ1's Avatar
Just put spark plug tester on it and turned it over... It has weak, intermittent spark in the low RPM range. Gonna pick up a new plug and try that I guess.
Old Apr 24, 2020 | 07:50 AM
LT80's Avatar
LT80 Expert
Did you get into the clutch's??
Old Apr 24, 2020 | 08:01 AM
SharpTJ1's Avatar
I swear I posted a reply.... Guess it disappeared in cyber space. Surprisingly, a new plug seems to have made a huge difference... It seems to be back to normal... It definitely didn't act like a plug issue to me...
Old Apr 24, 2020 | 06:35 PM
LT80's Avatar
LT80 Expert
Clutch's need serviced periodically. Glad it's running.
Old Apr 24, 2020 | 07:14 PM
SharpTJ1's Avatar
Is that just s matter of checking the Rollers and adding a touch of grease.
Old Apr 25, 2020 | 09:07 AM
LT80's Avatar
LT80 Expert
Pretty much, yes. Rollers should have no flat spots. The rear clutch bearings should be checked also.
SWBF
Jan 22, 2020 12:26 PM
SethL
Jul 27, 2004 04:23 PM
warrior68man
May 16, 2004 09:09 PM
trx270r
Nov 12, 2000 01:12 AM
