05 LTZ250 rearend
Old Mar 5, 2021 | 10:32 AM
JohnVH's Avatar
Default 05 LTZ250 rearend
Picked up a project, they stripped the splines on the axle spur gear, so they welded it to the axle, then broke the case part that bolts on.. Anyone know where to find used parts? New ones are a little spendy? Its part 27461-05GA1
Thanks
Anything else to look out for on these quads?
Old Mar 6, 2021 | 04:03 AM
It shares some parts with the Ozark, best check what you need against both Ozark and LTZ part numbers, there may be a few Ozarks being broken, but the rear axle is a bit of a problem with them too, OK if you keep the wheel bearings in good order but a worn wheel bearing transfers strain onto axle splines and diff, causing them to fail too.
Old Mar 8, 2021 | 12:48 PM
JohnVH's Avatar
Thanks, surprised how hard it is to find used parts. Everything is either riding them, or scrapped them? Hope I dont destroy the brake drum, they are expensive too..
shtopl
Jul 26, 2009 09:02 PM
bentagain
Jan 22, 2008 01:54 PM
flyinscrammy
Jun 21, 2006 11:44 PM
ThorMX902y
Mar 2, 2006 02:20 AM
