Need Help 2006 Suzuki Elgier 400
Old Feb 16, 2022 | 04:26 PM
Faroutfreak's Avatar
Default Need Help 2006 Suzuki Elgier 400
My son took our ATV out and was playing in some mud lakes. He drove through 4 or 5 times ( Water up to the floor boards ) on the last pass the bike just quit moving. Engine runs, revs up in gear but nothing moves in any gear, high or low 2 wheel, or 4 wheel, or reverse. It can does move by hand , but not by itself . Like I said the motor starts right up and runs beautifully. Could the Drive Belt have broke?
Old Feb 16, 2022 | 07:11 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Is it an automactic model if so may have damaged belt
Old Feb 17, 2022 | 07:55 AM
Default Thank you
Will be able to diagnose better today after I get it off the Trailer. I'll see if the drive shift turns ( Meaning rear end Problem ) or if the belt needs replacing . Thanks for your input.
Old Feb 17, 2022 | 08:34 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
He may have gotten water in the belt case. See if there is a drain plug for it or remove case cover and dry it out. The ATV will not move if there is water in there, done it myself.
Old Feb 17, 2022 | 02:29 PM
Default Fixed
After getting the Atv off the trailer today, I started it up and noticed it seamed to want to move just felt like the Auto Clutch was slipping. I opened the side cover, belt looked good, only a little water seepage. So checked the Clutch Adjustment, loosened both nuts turned the larger screw Counter clockwise until fully open, the tightened the smaller nut, turned the larger screw clockwise 1/16 to 1/8 th of a turn, locked down the nut ,and now runs like a champ again,( I just bought it used so apparently they didn't have the Clutch set up right ) Thanks everyone for your help and Advise , it got me started looking at other things than just the belt!
Old Feb 18, 2022 | 03:04 AM
If it has a clutch adjuster it is a manual, not an auto and won't have a belt. Manual Eigers are rather prone to clutch slip, Eigers and 400KQs are the only bikes on which I always adjust the clutch when doing a service.
Old Feb 18, 2022 | 05:38 AM
Ok I thought that since there is no clutch use during Shifting that it was the Semi Auto , It has 1 reverse, 5 forward ( Which you just shift as you need for speed etc ) I'll have to look as to why the Clutch handle is not hooked up ( It's there just doesn't appear to do anything, ) I'll have to do a little more investigation and find a Shop Service Manual . Thank you
Old Feb 18, 2022 | 08:53 AM
Dazeys's Avatar
If it's a manual shift then there is no clutch handle. That handle will be a brake handle.
ramon
Dec 11, 2011 07:10 PM
JTY2K
Sep 30, 2005 12:34 AM
ModifydZ400
Oct 9, 2004 01:19 AM
