05 vinson help
Old Feb 18, 2022 | 12:34 AM
Ronhill's Avatar
Default 05 vinson help
Starts up and runs great but when I run at Full Throttle after a few minutes it will backfire and then lose a lot of speed have to run it at that speed for roughly 30 seconds and I can get it back up to full speed for roughly a minute or two then backfire again back to a little lower speed not having any luck on finding a way to correct it
Old Feb 18, 2022 | 03:13 AM
Check the tank breather isn't blocked then check fuel flow from the tank. Difficult with the vacuum operated tap, but my guess is the fuel isn't flowing properly due to the tank filter blocked. Oddly enough I am cleaning out an Eiger tank today, (lots of water in it) but lots of paint flakes, grain and hay were stuck to the filter.
Old Feb 18, 2022 | 08:55 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
On my 02 Vinson there was a screen in the fuel inlet tube of the carb. I used a soft wire and some brake clean to clean it.
dranem
Apr 30, 2005 03:35 PM
Snug
Apr 4, 2004 06:32 PM
robinsnest
Jan 12, 2004 03:54 PM
