No lights, no electrical, no spark '93, Suzuki LT250
Old Jul 1, 2022 | 07:01 PM
Timbersteel's Avatar
Default No lights, no electrical, no spark '93, Suzuki LT250
Hello folks, I've run into a problem with no indicator lights, no headlight, no electric crank, no pull start, no spark with my '93 LT250.
I was able to pull start it, with the key in the ON position, but now, I've lost spark and I have voltage to the key switch, Run/Stop switch. I've tried jumpering the key switch for headlights, but nothing
This was my dad's 4 wheeler, but he's passed and I have nothing else to go off on.
Any help would be appreciated!
Old Jul 2, 2022 | 01:54 AM
The LT250 is a bit "before my time" regarding Suzukis but check that you have power to the key switch with a 12v incandescent test lamp, not just volts, also that the earths to frame and engine are good. You do have to know what you are doing to "hot wire" an ignition switch, otherwise you could feed pos to the kill wire on the CDI and blow it.
djjustus18
Tread Depot
Apr 4, 2013 10:27 AM
86zuk
May 21, 2012 05:03 PM
thestroker05
Nov 15, 2008 11:12 PM
PeteME
Aug 26, 2006 09:03 AM
LukeDuke
Feb 2, 2005 06:35 PM
