97 Xplorer 500 want start
Old Nov 14, 2008 | 08:47 PM
thestroker05's Avatar
Default 97 Xplorer 500 want start
My 500 will not start, when I turn the key nothing happens. My dash lights doesnt come on, my head lights want come on, when I hit the start button it acts as if your werent even pushing it. It acts like a dead battery, but the battery is strong. Before this happened I was riding it and the lights would blink on and off (headlights, and dash lights), I would then wiggle the handle bars from side to side and they would finally come back on. If I held the start button in and shook the handles bars I could get it to start from the starter. The atv will start by pulling the rope everytime, however, it will only shut off from the key, the stop button will not work. After it starts it runs great, no problems at all, just want do anything with the starter button and I have no type of lights. Someone please help me I am about to pull my hair out. Thanks in advance to all that help.
Old Nov 15, 2008 | 10:14 PM
Sounds like ignition switch wires possibly shorting out in harness area under pod,or switch itself bad,FIRST check for bare wires under pod causing problems,NOT a lot of fun I know! Good luck opt
Old Nov 15, 2008 | 10:20 PM
Would this indicate if the switch would be bad...I can pull the key out weather it is on or off....I was just thinking and thought I would ask. The iginition switch cause the head lights not come on. Thanks again for all your help
Old Nov 15, 2008 | 11:12 PM
Switch bad or wiring shorts if can pull key out and will still run! Lights could/should be a different problem,BUT as I've said with electrical anything possible! opt
cornermike
Jun 3, 2015 07:27 AM
cornermike
May 27, 2015 10:04 PM
1000gade
May 27, 2015 12:37 PM
rsoxfan
May 30, 2000 12:23 AM
rsoxfan
May 28, 2000 03:27 AM
