Gear position sensor
Old Oct 29, 2022 | 08:55 PM
ATVWolf's Avatar
Post Gear position sensor
Hey everyone, its me again. My 2002 Suzuki Vinson Quadrunner 500 isnt showing me the gear postions when I shift. The dash is working fine and every now and then it will show a "P" for park... but when in High or low or reverse it onle shows a blinking line. Is there a electronic senso that could be faulty ? If so where is is located ? Thanks for the help.
Old Oct 30, 2022 | 03:16 AM
There is a shift drum that goes more or less across the engine, on the Eiger the rotary gear position switch is in the case that holds the centrifugal clutch so I would guess that is where yours is. A spring loaded plunger pokes out of the end of the shift drum, as the drum turns round, the plunger touches a different contact of the rotary switch for each gear position, earthing each in turn. I would guess your plunger is dirty or the contacts on the switch, worn.
Old Oct 31, 2022 | 03:42 PM
ATVWolf's Avatar
Thanks a lot, this at least gives me a starting point to get the thing working right again...lol. I will update after I get a chance to look at it.
Cheers.
70runner@roadrunner.com
Jul 2, 2016 08:08 AM
serge167
Jan 4, 2009 08:35 PM
s.rye03z06
Sep 11, 2008 02:39 PM
nicks3
Jan 18, 2005 10:26 AM
