Ltf400 eiger hand shifter knob spring replacement
Old Mar 3, 2023 | 09:41 PM
Andy LTF's Avatar
Default Ltf400 eiger hand shifter **** spring replacement
Hey,
Does anyone know how to change the spring in the hand gear shifter tube located under the detent plastic rod? My spring is worn and no longer stops it from getting knocked out of hi/lo.
Old Mar 4, 2023 | 02:37 AM
Fairly sure all that does is stop you changing into reverse by mistake. It is the big spring above the shaft that goes into the gearbox which holds the lever where you put it. Item 3 on this drawing https://www.suzukipartshouse.com/oem...ing-2-model-k3 the big headed bolt can be seen sticking out of the alternator/gear case.
Old Mar 4, 2023 | 02:49 AM
Andy LTF's Avatar
Thanks Merriman.
yeah I want the spring working so the hand shifter so it stays in gear, as it slips into low from high occasionally if bumped while on the trails.
not sure if the pin is threaded in or pressed in (or needs to be drilled out for a new spring.
Carbcowboy1
Sep 18, 2020 05:33 PM
GixxerJim
Feb 26, 2008 02:20 PM
Gurney
Feb 8, 2006 02:59 PM
eiger2
Mar 7, 2004 01:52 PM
eiger2
Feb 2, 2004 10:48 PM
