2007 Suzuki Eiger 4x4 w/shifter
Old Jun 19, 2023 | 02:34 PM
olopawasuzukis's Avatar
Originally Posted by merryman
As I wrote before "an engine that "won't turn over" is seized" but will it really not turn over? That brass plunger is the choke and must have been loose. The plastic threads that screw the assembly into the carb seem OK, if they are, screw it back in the side of the carb and see if the engine will turn over on the pull start, if it won't on the electric.
Thank you for the information.
When the carburetor backfired, that brass plunger blew out and the plastic threads got wasted. I need to order another one and while were at it i am going to rebuild the carb.
a_tack
Feb 8, 2010 10:05 AM
95hog
Aug 13, 2007 02:21 AM
GixxerJim
May 8, 2002 03:46 PM
