throttle cable?
Old May 6, 2001 | 10:08 PM
stockyM's Avatar
How do you tighten the throttle cable mine streched. When you buy a new one how do you get the right length?
Old May 14, 2001 | 01:39 AM
PENNZILLA's Avatar
WELL SINCE YOU DIDN'T TELL ME WHAT YOU RIDE AND WHAT TYPE OF THROTTLE YOU HAVE (TWIST OR THUMB) I CAN ONLY TELL YOU WHAT TO LOOK FOR. THERE SHOULD EITHER BE AN ADJUSTER AT THE THROTTLE HOUSING (PROBABLY WILL HAVE A RUBBER SLEVE OVER IT TO KEEP WATER OUT) OR THERE WILL BE ONE ON TOP OF THE CARB WHERE IT GOES INTO THE CARB THERE MAY ALSO BE A RUBBER COVER OVER THIS ONE AS WELL. IF YOU ARE RUNNING STOCK EQUIPMENT THEN YOUR DEALER CAN GET YOU THE CABLE, IF YOU ARE RUNNING A DIFFERENT CARB OR TWIST THROTTLE THEN YOU CAN CONTACT MOTION PRO AND TELL THEM WHAT YOU GOT AND THEY CAN MAKE A CABLE FOR YOU.
pgamboa
Dec 24, 2023 11:52 AM
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
craacker
Sep 9, 2015 04:32 AM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
