quadzilla carb
Old Jun 2, 2001 | 11:55 AM
waynaferd's Avatar
I was just curious what size it was, and if I could benefit from a bigger one or just rebuild the stocker......thanx
Old Jun 2, 2001 | 11:10 PM
PENNZILLA's Avatar
Well it has been years since I had a stock carb on a zilla but I do believe it is a 38 mm. Yes you will benifit from the larger carb, If you want the best setup get in touch with Tudors performance (go to www.quadzillathon.com to get his link) he will hook you up with a 41 mm with a power jet machined into it. then throw in a k&n filter for more flow and you will have more response.
Old Jun 3, 2001 | 12:54 PM
waynaferd's Avatar
Is it a Mikuni Flat-slide? I took mine off yesterday but don't know if its original or not...
Old Jun 3, 2001 | 04:22 PM
PENNZILLA's Avatar
YES THAT IS THE STOCK ONE, IF YOU DECIDED TO STAY STOCK AND NEED A CARB I HAVE 2 FACTORY CARBS THAT ARE IN GOOD SHAPE.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
