bad vibes
Old Jun 22, 2001 | 01:18 PM
bdscram1's Avatar
I have a 86 lt250r and when the clutch is pulled in its fine. when I let out the clutch in nute,or any gear it is felt better in nute. it vibrates and knocks real bad took off the clutch cover and I can wigle the clutch basket. took off the basket and tried to wigle the shaft moves a very little but not as much as the basket. the motor is apart due to losing a spacer by the wrist pin and causing a lockup. so it is off to get a port and polish so I want to fix befor I get it back.
thanks for your help
Xbdscram1
Old Jun 22, 2001 | 11:56 PM
bermbanger's Avatar
Make sure the counterbalancer is lined up.
Old Jun 23, 2001 | 11:51 AM
bdscram1's Avatar
counter balencer is fine Im sure its in the clutch
later
Xbdscrambler1
Old Jun 23, 2001 | 06:22 PM
bermbanger's Avatar
check the bearings the clutch basket housing is connected to.
DesertViper
Jul 11, 2005 04:10 PM
modquad
Apr 3, 2004 10:28 AM
airtimehocutt
KTM
Oct 15, 2002 09:25 PM
